3s2p vs 3s1p
neweuser
neweuser's Avatar
3s2p vs 3s1p - 02.14.2008, 03:35 PM
If these are the same MAH, can the 1p perform as well as the 2p?
Maxxman
02.14.2008, 03:41 PM
I believe the 1p's voltage would drop more than that of the 2p's under the same load and therefore heat up more.
02.14.2008, 03:58 PM
If the total pack mAh and C are the same, it shouldn't matter. 2p @ 1Ah is the same as 1p @ 2Ah.
However, if the 1p pack is made of one 1Ah cell, and the 2p is made of up two 1Ah cells, the 2p pack will perform better.
SpEEdyBL
"Out of spec" enthusiast
SpEEdyBL's Avatar
02.14.2008, 05:15 PM
If the total capacity is the same e.g a 2s2p 2000 mah pack (1000 mah cells) vs. a 2000 mah 2s1p pack, it is better to use the 2s1p pack because bigger cells tend to perform better at high C ratings than smaller cells. Also the chance of getting a bad cell is reduced by 50%.
Area 52 Ranch Raceway
T.R.C.R.
neweuser
neweuser's Avatar
02.14.2008, 06:38 PM
So the performance would be the ah of the cells. For example: if the 1p is 1ah, but the 2p is 2ah, obviously the 2p would perform better. But if they are the same ie: 1ah cells, then performance is basically the same. Correct?
hoober
02.15.2008, 05:57 PM
You can pretty much ignore any reference to P numbers. It is always figured in when describing the capacity and current capability of a pack.
neweuser
neweuser's Avatar
02.15.2008, 06:02 PM
Sounds great. 1p it will be then. :)
Matthew_Armeni
Matthew_Armeni's Avatar
02.15.2008, 06:08 PM
I started a thread on this a little while ago, lots of good information was posted. Check it out here.
Another one about battery setups is here.
Just some info to look at, interesting stuff, enjoy
  Send a message via AIM to Matthew_Armeni
neweuser
neweuser's Avatar
02.18.2008, 02:29 PM
Thanks....'
Edit: that was great info, yes indeed.
Thank you
