BEC and Novak HV system
Gee
A Horse's Ass
Gee's Avatar
BEC and Novak HV system - 02.18.2008, 05:34 PM
Can you run a BEC with a Novak HV 4.5 setup?
Sorry I found it
If using an external receiver battery pack with the HV-Maxx ESC:
1. Plug an external 5 cell (1.2VDC/cell) receiver battery pack into
the battery slot of the receiver.
2. Leave the HV-Maxx’s ON/OFF switch in the OFF position, and
use receiver battery pack’s ON/OFF switch to turn the system
power on and off––Do not use the ESC’s switch.
12VDC BATTERY NOTE: An external receiver battery pack should be used
when using the HV-Maxx with a single 12 volt battery, like a lead acid or
gel cell. The ESC’s built-in B.E.C. will provide limited output due to the
high voltage directed through the single battery input, resulting in
degraded servo and receiver performance.
Any comments though?
Matthew_Armeni
Matthew_Armeni's Avatar
02.18.2008, 05:38 PM
Are you asking if you can run a seperate UBEC with the Novak HV controller and a Novak 4.5? If so, then yes. I believe you can run a UBEC with any controller as long as you disconnect the red wire from the ESC to the RX.
  Send a message via AIM to Matthew_Armeni
Matthew_Armeni
02.18.2008, 05:50 PM
Why do you want to run a seperate BEC? Are you running a single pack?
SpEEdyBL
"Out of spec" enthusiast
SpEEdyBL's Avatar
02.18.2008, 05:55 PM
I used to run a single 4s pack without ubec, and I didn't have any problems. I switched over to using ubec because I thought it I could be damaging something, but i didn't notice much of an improvement temperature and and performance wise.
Area 52 Ranch Raceway
T.R.C.R.
Gee
A Horse's Ass
Gee's Avatar
02.18.2008, 07:05 PM
I had an HV esc burn up in the evo and replaced it with a MM and and extrenal BEC. It made a differnce in longer run time and also the LVC cutoff of Novak would start cutting out several minutes before the actual cutoff. It would also shut you down when you'd spike below the LVC. The batteries would still be above the LVC setting. I was wanting to put that BEC in my e-maxx that also has the HV 4.5 in it to see if the BEC is the reason or if it is the mm with the firmware/software upgrade that is making the differnece.
Just playing around to learn more about it. Like what makes the BEC different from a receiver pack? With a BEC you need to remove the red wire but a receiver pack you don't?
Matthew_Armeni
02.18.2008, 07:24 PM
With an external BEC and Novak's ESC you probably do not have to remove the red wire as long as you keep the ESC switch off like the directions state. The BEC and rx pack basically the same as far as the rx and esc are concerned, so Novaks wiring must be different somehow with respect to turning it on and off.
VWT4
02.19.2008, 11:22 AM
I thing the issue is that the Novak HV gets the current for the BEC from ONLY one of the connectors (I think is the right one).
If you use 6 or 7 NiMH cells packs the BEC works reducing 7,2 or 8,4V to 6V for the receiver and servos.
Using a 12V lead battery or 4S lipos in this connector will overload the BEC and can burn it.
