E-maxx Swaybar
superlightmaxx
superlightmaxx's Avatar
E-maxx Swaybar - 02.23.2008, 10:14 AM
Any of you racer run swaybars on your E-maxx? If you do, what kind do you run? I bought one set but it looks way to stiff and is really heavy and bulky so I never even put it on!
thanks guys!
Working on:
Twin CF GorillaMaxx (8S motors on 2x2slipo)
2WD AL. GorillaMaxx (7lbs with batteries)
10kmahE-maxx
02.23.2008, 08:23 PM
I was reading your sig, what did you do to get ur E down to 7.5lbs, besides a single motor setup w/ lipo. Because the AL shock towers would add weight, and the rpm Steel cvd's also add weight, especially if your still running 4WD setup.......
i have converted to 2wd, 1 shock per wheel, removed shift servo, and 7075 T6 pillow balls, TI hingepins, and i'm only down to 10lbs w/ batts
t-maxxracer32
t-maxxracer32's Avatar
02.24.2008, 02:42 AM
10kmahE-maxx
you using 10k mah batteries? that may be why?
im sure that adds a little more than a pound?
superlightmaxx
02.24.2008, 11:32 AM
these is the weight reduction I did:
feigao 8l motor 275 compared to 450 stock motors.
panther komodo tires and rpm rims 140g each (compared to stock 325g)
4 shocks only (-80g), al. pivot ball (-40g), al. turnbuckles (-30g), no front and rear bumpers and cut skids (-75g), single speed (custom made -50g) no shifting servo (-50) all this adds up to a swift 3000g on the scale and my 2s li-po weight 200g each so it adds up to 3400g with batteries! :O) anybody can do it, just not with big 8000 li-po.
Gorillamaxx shock towers weight the same as stock when using 4 shocks,
you should weight yours without batts to see!
Working on:
superlightmaxx
02.24.2008, 11:34 AM
with regular "legal" race tires the superlightmaxx is only a lightmaxx and weighs in at 3600g or 7.9lbs. :O)
Working on:
superlightmaxx
02.24.2008, 11:35 AM
to lose a LOT of weight the first place to look is tires/rims and second is batteries...
Working on:
10kmahE-maxx
02.24.2008, 02:01 PM
No i don't have 10k mah batts/ lol that was just the name i came up w/ and its pretty dumb.
Wow thats awesome, you have inspired me. My goal was 8lbs RTR but i didn't think it was possible.
Are you running AL or stock skids ?
Which RPM rims ? I have the offset claws from RPM
Without batts its just over 8lbs, But i'm still stuck w/ stock titans and 7 cell NiMH packs,
i plan to get the new Mamba kit when it comes out..
superlightmaxx
02.25.2008, 01:44 AM
RPM rims are 55g each for the Titan and 48g each for the claws! I habe both! The new LPR rims and tires from prolines are pretty light also (185g) and with 4000 4s li-po you sould be able to reach 8lbs no problem...
I run stock plastic skids, stock bulkheads and arms! only parts in aluminium I put in is the gorillamaxx chassis, shock tower and motor mount cause it didn't add any weight. I always take weight off, never addind more unless nesserary... like the cvd's but that 100g that's really worth it! lol unless you like changing your plastic driveshaft every race!
Working on:
