Tomato's E
tomato
tomato's Avatar
Tomato's E - 08.17.2005, 01:53 PM
Hey Guys,
Here it is so far. I just got some greendot foams to make the most of the street out front. There's got to be some lost speed in ballooning tires! Now I gotta savew and get a better brushless.
MetalMan
MetalMan's Avatar
08.17.2005, 02:05 PM
Nice! You do need a better brushless system :) I don't think I have ever seen Maxx foams actually mounted before!
tomato
tomato's Avatar
08.17.2005, 02:38 PM
Imex makes them. I was hoping the lack of vibration would due it some good. Aside most of the other tires seems to be off road based and my yard seems to tear up the light weight tires fast. I'll use the foams to check it out on full speed runs and the stocker for bashing it up! I'll retire the HVMAXX in my son's rc10t2. It's got a titan and EVX in it now and it's very fast. I can't keep it straight enough to get it up to full speed yet. I need to slow the steering rate down. I'll let everyone know about the foams. I don't know what to expect. They are a little skinny though.
Dafni
Dafni's Avatar
08.17.2005, 03:43 PM
They are skinny, but this also helps steering response.
The 40 series Roadrage is also a good onroad tire. To bad nobody makes good 40 rims.
Serum
Serum's Avatar
08.17.2005, 04:27 PM
Too bad nobody makes good 40 rims
proline makes the best 40 serie rims! the 23 mm adaptor sized types.. the dish version, cheyenne, and the spoke 40 serie. All with the 23 mm adaptor..
Promod
08.17.2005, 04:55 PM
I tried foams but could never get them to hook. Anything over half throttle and it would 360. But you could have better luck with them.
Thank you,
Promod
tomato
tomato's Avatar
08.17.2005, 05:05 PM
Thank you,
Promod
That doesn't sound very promising:W: We'll find out in a few more hours.
I rigged up some carbide balls in the spur/slipper. I wonder what's going to melt first?
Serum
Serum's Avatar
08.17.2005, 05:10 PM
I guess the foam is too hard then..Though Promod is not a reference.. He normally uses 5KW+ systems in a 10 lbs maxx...
Your using a Novak, you could use the normal slipper thingys..
tomato
tomato's Avatar
08.17.2005, 05:22 PM
What ever those peg things are they certainly don't work. Your lucky if they last one set of batteries.
Dafni
Dafni's Avatar
08.17.2005, 05:27 PM
Then you prolly had the slipper too loose. Also, try 12 pegs instead of 6.
Stock spur and slipper actually works fine for me, for as long as you don't allow too much slippage (or any at all:C: ) Thing get's hot.
Serum, I don't know about the 23mm wheels. But the PL 40 standard wheels were a big dissapointment for me. They beginn to wobble after a while.
tomato
tomato's Avatar
08.17.2005, 05:36 PM
Uhggg. I got the standard result. Went about 4 feet and busted something in the tranny. Makes me want to get a Jato....
Now to take it all apart again....I'm tired of wrenching on it. I want to drive it. What part do you suppose I broke this time?
Dafni
Dafni's Avatar
08.17.2005, 05:44 PM
You're still on stock idlers?
Sorry to hear about your bad luck.
tomato
tomato's Avatar
08.17.2005, 05:45 PM
No. I got the UE's
tomato
tomato's Avatar
08.17.2005, 06:14 PM
LMAO. Well The GMAXX chassis lends itself nicely to removing the tranny. I just wish I would have wiggle the gear shift before I took it out!Seems I may have been stuck between gears.
tomato
tomato's Avatar
08.17.2005, 06:57 PM
Well I just got back in from the outside and it was a blast. You can actuatly turn on a dime with the foams. The green dots seemed to be a good choice. No real slippage. You can powerslide through the turns. I used improper gearing with a fan and it ran coolish. About 120. I don't think that to hot is it? I can't wait to see this thing with another motor in it.
