strange lipo behavior
Topspeedtimmy
trick mad power (tmp)
Topspeedtimmy's Avatar
strange lipo behavior - 02.28.2008, 11:16 PM
I got a couple 3s 3800 mAh packs, and it first started charging to 3100 mAh. This is from charging 9.3-9.8v to 12.42v. 30 cycles later it has been dropping in final charge capacity every cycle. Now it is charging to 2200 mAh, got any ideas? I'd hate for a $200 set of packs to go in only 50 cycles
jadesportster
02.28.2008, 11:44 PM
How are you storing the packs when not in use? Storing them empty can cause a limited charge.
Are you using a balancer?
skellyo
skellyo's Avatar
02.29.2008, 12:06 AM
What brand are the Lipos?
Topspeedtimmy
02.29.2008, 06:43 PM
They are those dang ol' Apogee magnum packs. And I haven't stored them for more than about 2-3 weeks. But when they're sitting there, they're at 9.3v-10v ready to be charged. They are also balanced every 5 cycles or so.
bdebde
That's All Folks!
bdebde's Avatar
02.29.2008, 06:53 PM
If you are storing them for any length of time (more than a couple days) at less than 10v, that may be the problem. I always put a storage charge on mine after they cool down; or at least within a day or two. I have several packs that I have been running for over a year with no apparent loss of capacity.
What are you running these in? What kind of temps on them after a run? If the battery is undersized for the application, that will also cause problems.
Topspeedtimmy
02.29.2008, 09:37 PM
Ran them in a VXL/Mamba Rustler for the first 20 cycles, then in the Revo. Usually 75-100 degrees after the run.
JAM
MaxAmps Marketing Manager
JAM's Avatar
03.10.2008, 02:13 PM
Sorry but this is the MaxAmps support forum not Appogee.
Jason
Jason
jason@maxamps.com
www.NitroKillers.com
www.MaxAmps.com
  Send a message via MSN to JAM
