spur gear tooth count for .5 crt
nitrorube
nitrorube's Avatar
spur gear tooth count for .5 crt - 03.05.2008, 09:09 AM
hey guys i was trying to use the calculator that mike has for motor selection for my .5 crt project and i dont know the spur gear tooth count anybody know,thanks
03.05.2008, 09:40 AM
46t..
nitrorube
nitrorube's Avatar
03.05.2008, 10:43 AM
thanks
jnev
jnev's Avatar
03.05.2008, 01:51 PM
Are there any smaller spur gears available? Like a 44t?
03.05.2008, 02:14 PM
Short answer: no.
Long answer: Depends. The CRT.5 uses something close to 8th scale parts, but unless you want to modify the CD mount, CD bearings, and change the center shaft length to allow the space for a real 8th scale diff (or even just a regular spur), you are stuck with that spur. This is one of the primary reasons why people use the hardened pinions - because they are stuck with the steel spur.
03.05.2008, 03:06 PM
Only bigger...
Part # Description Price
6046 Jammin Crt .5 Hardened Steel Spur Gear 46 tooth $28.50
6047 Jammin Crt .5 Hardened Steel Spur Gear 47 tooth $28.50
