Could someone tell me if its normal to have my mgm 160 go to full trottle as soon as you pull the trigger?? i tried to set everything i can think of. its my first mgm so im not sure if this is normal. if i want to go slow i have to play with the trigger becouse as soon as i leave it at the same place vroom full speed i go. theres only full speed or brake. i set the ms to almost 2 sec to so i dont take off tooo fast thanks:
Reason: spelling
I think your Tx setup is not correctly configure. Have you "learn" to your MGM the full end point of your Transmitter? Full trottle, full brake and neutral?
And be carefull, if you have a Futaba radio, you must reverse the trottle in the transmitter.
i setup my tx again tonight tx on then full trottle put esc on 10sec 3beep brake for 1 beep put esc off. should be ok. but for a reason as soon as i press the trigger she goes to full trottle.
