Possible cogging ??
crash-course
Possible cogging ?? - 08.22.2005, 02:00 PM
I've been having a problem with my brushless setup while trying to lift the nose while in the air to correct my landings. When I gas it, the motor momentarily stops or slows down before spinning again. As you can imagine, if I'm already needing to lift the nose and this happens, it causes some really ugly body first landings.
It's doesn't appear to do it all the time, but it only takes one time to break parts.
This has been a problem on several of my setups but it's to bad with 2WD. With the maxx it's terrible when it happens.
My setup is:
10L
9918
12 cells
16/70 gearing
controller's BEC
Response tires.
Anybody else have this issue and know how to fix it? Is it BEC related? The voltage shouldn't drop below the cutoff with 12 cells right?
Serum
Serum's Avatar
08.22.2005, 02:04 PM
My guess is it's BEC related.. (though it should work with 12 cells, according to Mike..)
What batteries are you using?
Dafni
Dafni's Avatar
08.22.2005, 02:12 PM
To exclude the BEC from the "what's the problem" list, try a receiver pack. (Don't forget to disable the internal BEC by pulling the red wire or removing the black jumper).
If it works with a rx-pack, I would suggest an UBEC.
Hey, your username kinda matches your problem:p
Hope you get this sorted out!
DAF
crash-course
08.22.2005, 08:54 PM
matched GP3300 and IB3800. I'm also using an XS3 FM radio so I don't think it's interference. I'll try a receiver pack and see if that helps.
A crash course is the only way to learn.
