hellfire
mamba hellfire
hellfire - 03.22.2008, 09:55 AM
I just finished converting over to brushless.My setup is:
Mamba with fan
Novak HV 4.5
True rc 4s 8000mah
I made the conversion myself [battery tray,esc mount,motor mount]
On a 45 degree day after 15 min of running motor temps were 80 degrees and the esc was at 145, this is before I put the fan on.
ID:	4262   Click image for larger version
ID:	4263   Click image for larger version
lutach
lutach's Avatar
03.22.2008, 12:32 PM
Looks good. You should try the 5mm conversion for the HV motor when they come out. I will be buying it for sure.
mamba hellfire
03.22.2008, 12:51 PM
I have the 5mm on order at hobby store.
03.22.2008, 03:29 PM
I just got my 5mm conversion and threw it in a brand new 6.5hv. I may test it with 3s in the crt.5 and see who it compares to the plett maxximum.
lutach
lutach's Avatar
03.22.2008, 03:35 PM
It's out already?
03.22.2008, 04:43 PM
Yep, my LHS ordered it from great planes, so Tower hobbies should have it available. It went together nicely, and the shaft has a flat area grond on it all the way to the bearing. Nicely made just like all of novak's motors.
The rotor is small in diameter, but long so I think it will make a nice 3s motor fot the crt.5. Not sure if it will be better than the plett, but the 1/8" shaft on the plett was bothering me, as there is no slipper on the crt.5. I may put the plett in an emaxx on 4s, and see how it does!
GO-RIDE.com
03.24.2008, 10:32 AM
Lincpimp keep us updated on the Novak HV with 5mm. However, I've found that the 1/8 motor shaft is not the weak link. It is the center drive shafts. I seized the main bearing in my Novak 6.5 (non-HV) and both center drive shafts bent, but not the motor shaft. This happened when I was at full speed WOT on the back straight at my local track. I was even running very grippy clay specific truck tires. Of course other motors may not have as high quality shaft as the Novak stuff?
E-8ight - Tekin RX8 2000kv/4S
mamba hellfire
03.25.2008, 07:33 PM
My LHS called today and my 5mm upgrade came in.
Hopefully I will have it in by the weekend.
