kb45-540 mount adapter 30mm-25mm
kb45-540 mount adapter 30mm-25mm - 03.30.2008, 02:13 PM
somebody purchased an adapter to change the mounting screw size and pattern, anybody remember it, and where to get one? any sources for 6mm pinions?
03.30.2008, 02:33 PM
Pinions can be found on sdp-si, but they are not hardened. The mount adapter was by bl-power, he sent me one, but it was too thick, not enough of the shaft was left to secure the pinion to.
I removed the front endbell, unscrewed it. Then drilled and tapped it for m3 screws in the std bolt pattern.
VWT4
03.30.2008, 03:25 PM
I did the same and works great.
