Best route?
jkp41
I'm a real doctor!
jkp41's Avatar
Best route? - 03.30.2008, 09:44 PM
I'm trying to plan out my next vehicle to do, and I think I've finally decided to convert a revo this summer.
For those that have had experience with them, which route of conversion is preferable?
1. Using the revo tranny and rcm mount or teckno kit, or
2. Using the 3905 emaxx tranny and modifying the chassis to fit it
I like the idea o the emaxx transmission, and that is what i'm leaning towards right now. To me, it seems to look cleaner and just seems to be more my style, but the teckno kit looks to be an easy bolt on conversion. The maxx version also seems to be the more economical route as the only big thing I would really need to buy would be the transmission. I would probably rob the 7xl/mm off my maxx and convert it back to stock to play in the water and mud. With the teckno route, I would have to by the kit which is significantly more $$$.
Second question, would it be cheaper to order a rolling chassis form somewhere like ebay or from this site, or just building it up piece by piece?
Sorry for the long post and multiple questions, I just wanna go the best route and do it right, and yall seem to be the most knowledgable people that I've found. Any ideas, suggestions, criticism, etc is appreciated. Thanks!
azjc
03.30.2008, 10:44 PM
I am in the process of a Revo BL conversion, and presently waiting on the release of the MMM to see how it performs or I will go with a MGM esc, but I am going with the RCM motor mount, using the Revo tranny, I have removed the 1st gear, installing the FOC and center diff. As far as battery I will be using a Flightpower 5000mah 6 cell lipo, and a Neu 1515/2.5d....this seems to be the simpliest route. I originally bought a the Revo off of Ebay with a blown 3.3 engine
jkp41
I'm a real doctor!
jkp41's Avatar
03.30.2008, 10:53 PM
I do agree that that is the simplest route. I'm just wondering what the best route would be. I'm liking the looks of the 3905 transmission, and if I go that route, I'll probably copy stumblin's design mostly (imitation is the most sincere form of flattery ). I'm curious as to how well that conversion holds up and what not.
03.30.2008, 11:16 PM
The emaxx tranny will be the simplest way, an so will a roller. You can sell the stock revo tranny and some of the other pieces. The tekno tray and staps are good for the battery. Or just buy a rcm mount and mod the tranny to be locked in second. Either way will work.
jkp41
I'm a real doctor!
jkp41's Avatar
03.30.2008, 11:32 PM
Thanks! Does the sickhobbies price seem reasonable or should I try to find a used one from ebay? I like the idea of a new roller and not inheriting someone else's problems, but would also like to cut out some of the cost of the build.
03.30.2008, 11:39 PM
The 275 dollar option looks good, as it has all of the servos, which will sell for more than 20 bucks. You can look around on rctech and the traxxas forums and get a used roller cheaper. I bought a used roller, and it had a ton of spares for 150. Look around and seewhat you can find.
Jbreddawg
Jbreddawg's Avatar
03.31.2008, 08:24 AM
Cool site but if you dont mind a little extra effort you can do the same thing they do. I picked up my complete rtr revo with loads of hopups for 300.00 on ebay . I parted it out , kept what I wanted and ended up with a loaded roller for 107.00 . Jerry
jkp41
I'm a real doctor!
jkp41's Avatar
03.31.2008, 05:35 PM
Well buying used, the 2.5 revos are, in general, a good bit cheaper than the 3.3. For what I would be using of the rolling chassis (3905 transmission swap), what would be different on these versions aside from swapping out the chassis itself?
03.31.2008, 06:58 PM
The 3.3 uses the same length front and rear driveshafts, and the steering links are longer. Plus the tranny case is different for use of the rear brake kit, but that will not matter if you will use an emaxx tranny.
jkp41
I'm a real doctor!
jkp41's Avatar
03.31.2008, 09:14 PM
That sounds easy enough .
