Do you have the cups and such and just need the bone? Do you need the whole setup? Both the front and back are the same. http://www.unlimitedengineering.com/...re/13513T.html
Part # 13513t I think that is what you talking about. That is a kit though.
Peace!
Country
Help support the
Rc-Monster Buy here
I use to have a Torpedo chassis and had the UE cups. My Torpedo broke though and I cannot order another one. I went with the Gorilla maxx chassis, so all I need is the bone. I just don't know how many millimeters the one you linked is.
Well now. I can tell you this much. The extended bone is 100.5mm. If you take an inch which is about what the extension stretches you out at 25.4mm per inch. I would have to say the 70mm version. I have one here. It comes out to 7cm for center pin to center of pin. That is all i can do for you. I hope it helps you. I tried my best.
Peace!
Country
Help support the
Rc-Monster Buy here
UE measures from pin to pin. Many mfgs measure the total length. as long as the measuring technique is known, then that is what is important. You can get the appropriate size from this info.
