Castle Creations Bec
Jammin
Jammin's Avatar
Castle Creations Bec - 04.01.2008, 10:47 AM
I have the MM system with the castle link and a cc bec. How do I use the link to program it. I don't know how to hook it up.
04.01.2008, 10:49 AM
It programs through the throttle cable, so hook the USB end of the link to your PC, hook the other end of the link to the throttle cable on the BEC.
Jammin
Jammin's Avatar
04.01.2008, 10:54 AM
Gotcha, I don't have the castle link then. The cable that came with my mm is just a cable right?
04.01.2008, 11:09 AM
No special link cable - about $20
http://www.castlecreations.com/produ...stle_link.html
azjc
04.01.2008, 11:30 AM
program the BEC before you connect it to the ESC, there have been some issues with the castle link program getting confused if you try programming after you connnect
DRIFT_BUGGY
DRIFT_BUGGY's Avatar
04.01.2008, 05:28 PM
I haven't got it yet but trying to work out how to install it when I get it. By the looks of the photo the black and red wire go to battery and the ESC goes to Channel 1 (which is for steering) and BEC goes to Channe 2 for throttle which makes no sense, where is the steering throttle mean't to go??????
04.01.2008, 05:36 PM
Thats a rather simplified diagram in terms of the Rx hook-up, look at BrianG's diagrams:
http://www.scriptasylum.com/rc_speed/_wiring_bec.html
Select 'UBEC wiring option' 1 or 2.
Serum
Serum's Avatar
04.01.2008, 05:41 PM
Amen, Brian's page is the remedy..
xcntrk
xcntrk's Avatar
04.01.2008, 08:29 PM
Note that the CastleLink is only intended for the CC-BEC and other (non-MM) controllers. The Mamba Max specifically is only programmable through the on-board USB port, not the 3-wire receiver terminal. I too ran into this issue recently and it’s clearly stated in the Castle Link software (great interface btw). Also you can program the CC-BEC while it’s installed/interfaced with your ESC. You simply have to “turn-off” the enable/disable toggle switch for the ESC and the CC-BEC will sync right up.
abiye
04.01.2008, 10:10 PM
i wonder if you can use a Mamba max esc as a castle link to program the cc bec... maybe someone can try it and let us know...
