Mike's Li-SAVER
andy85
Mike's Li-SAVER - 04.02.2008, 08:42 AM
I'm just about to order mike's li-saver. Question is how many cells can it handle? and what voltage does it cut off at?
jhautz
jhautz's Avatar
04.02.2008, 09:12 AM
The Li-saver is good for 2-10 cells.
I dont see it in the documentation anywhere, but I believe it cuts off at 3.0v/cell.
to make it...
or break it...
Silent...But Deadly
andy85
04.02.2008, 05:39 PM
nice one...
has any had any issues with this save cutting out too low?
rchippie
rchippie's Avatar
04.02.2008, 06:25 PM
I have used the lisaver on 4s with no problem at all.
REAL MEN RUN BRUSHLESS
andy85
04.03.2008, 09:26 AM
how does this li-saver react when voltage is low? total cut off or reduced power?
jhautz
jhautz's Avatar
04.03.2008, 05:52 PM
Total cut off. going back to neutral resets it and you can move again to get it off the track, but you shouldnt drive after the cut out.
to make it...
or break it...
Silent...But Deadly
04.03.2008, 05:59 PM
Nice - Would be a great feature to include with CC UBEC... option to cut power to RX...
andy85
04.04.2008, 10:46 AM
thanks for d input guys!!!
captain harlock
RC-Monster Captain
captain harlock's Avatar
04.04.2008, 05:24 PM
I'll definately get it for my Schulze controller.
Nice to meet you!
kulangflow
Never Fast Enough
kulangflow's Avatar
04.25.2008, 06:12 PM
Here's a question: Have any of you had problems with the li-saver cutting too early?
If I jump on the throttle, the truck jumps forward and immediately (violently) stops, which makes me think that the li-saver is cutting in.
The truck drives fine if I'm easier on the throttle (more gradual). If I bypass the li-saver, the truck acts like I expect it to and wheelies all the way down the road.
Are my batteries just dropping that much voltage that it trips the lvc, or is the lvc too sensitive or set too high?
Thoughts?
(Set-up: BL-Revo, MM, UBEC, 2 x 2s 6k lipos fully charged, Spektrum rx/tx)
Thanks!
jnev
jnev's Avatar
04.25.2008, 06:37 PM
If those 6000mah lipo's are the Max Amps ones, then they are probably the problem. They tend to drop their voltage without even a huge load on them.
kulangflow
Never Fast Enough
kulangflow's Avatar
04.25.2008, 07:08 PM
They definitely drop their voltage under load more than higher quality packs, but they were fresh off the charger at 16.8V. They can't be dropping that much voltage, can they? The same packs don't trip my MM's LVC.
I think I need to hook up my Eagle Tree to see what's happening when it cuts out like that.
Thanks again for your help.
jhautz
jhautz's Avatar
04.25.2008, 08:28 PM
I remember having a similar problem when I first used that Lisaver. I was using 5s 8000mah 10C batteries in a heavy savage. I changed to better batteries and havent seen it since. I actually forgot about it until I read this post. The LiSaver seems to have a very hard cut off. If it touches 3.0v it shuts down.
I would be interested to see your eagle tree data though. I never did that... but probably should have looking back.
to make it...
or break it...
Silent...But Deadly
04.25.2008, 09:25 PM
Any reason why you are not using the internal lvc on the mm? I have used it all of the time when running 4s, and works fine.
kulangflow
Never Fast Enough
kulangflow's Avatar
04.25.2008, 09:35 PM
Oh oops, I wrote the wrong thing earlier when I posted the set-up.
The li-saver is being used with a BK9920 in my Revo.
I used to have an MM in the Revo with the same motor and packs and the MM LVC didn't trip like this one does.
I'll try to get the EagleTree data tomorrow. I'll also try it with 5s True R/C 8K packs to see if it does the same thing.
