diff direction...conversion in t-maxx, can I reverse direction of center diff
diff direction...conversion in t-maxx, can I reverse direction of center diff - 04.07.2008, 07:57 PM
Can I reverse direction of the center diff w/ out any probs.? It would be MUCH easier to mount this way. With an electric motor it would seem to be able to do this, but not sure.
brushlessboy16
brushlessboy16's Avatar
04.07.2008, 08:03 PM
r u using the tmaxx tranny?
xcntrk
xcntrk's Avatar
04.07.2008, 09:00 PM
^Dito
The traditional Tmaxx tranny will nuke on BL power unless you FOC it. Otherwise you can simply mount the entire tranny backwards to reverse rotation. For example, I too run a Tmaxx conversion using an Emaxx tranny that's mounted backwards (motor to the rear).
Tmaxx BL Conversion
Hyper-7 Truggy
E-Slayer
brushlessboy16
04.07.2008, 09:29 PM
yep emaxx tranny for sure
its me
There is no help for me... I'm addicted to R/C
its me's Avatar
04.08.2008, 12:07 AM
If its a true 1/8th center diff then direction will not matter.
rccna.com
04.08.2008, 07:43 PM
it is a true center 1/8 diff..I was hoping it didn't matter for it will make my conversion that much easier
its me
its me's Avatar
04.08.2008, 11:53 PM
Then your good, wont actually matter which way it spins. There's only spider gears in it.
rccna.com
