3.3 shopping list
highflier
Emaxx- FLM wannabe
3.3 shopping list - 04.12.2008, 09:18 PM
Hi all,
It was only a matter of time before I broke a rear drive shaft. I just want to make sure I am getting the right stuff. I am trying to stay cheap but realiable LOL.
My truck is a FLM chassis, stock tranny & diff's, RPM arms, I had upgraded the tires to Badlands, new rims and also got the larger hex hubs (Ofna). Now I want to add 3.3 conversion I think.
Is this what I need.
qty 4 http://www3.towerhobbies.com/cgi-bin...?&I=LXMJG8&P=7
qty 2 http://www3.towerhobbies.com/cgi-bin...?&I=LXLMV7&P=7
qty 1 http://www3.towerhobbies.com/cgi-bin...?&I=LXMJE0&P=7
qty 1 http://www3.towerhobbies.com/cgi-bin...?&I=LXMJE1&P=7
qty 1 http://www3.towerhobbies.com/cgi-bin...&I=LXHGB7&P=ML
qty 1 http://www3.towerhobbies.com/cgi-bin...?&I=LXHGC9&P=7
Is this stuff going to plug right in without mods and is it the right stuff?
Is this everything needed to complete the 3.3 conversion?
Is everything here required or is some of the stuff on my truck compatible?
Highflier
highflier
Emaxx- FLM wannabe
04.12.2008, 09:35 PM
1 more question,
I noticed that the traxas carriers are much cheaper on Ebay. Any reason that I should stick with the RPM carriers?
Highflier
wade7575
04.12.2008, 11:01 PM
I do not know much about the conversion stuff but the one thing I can tell you for sure is go with the rpm carries they use a bigger bearing that will fail much less than the stock traxxas one's the traxxas ones fail alot,the rpm ones will stand up alot longer.
mriccucci
mriccucci's Avatar
04.13.2008, 10:35 PM
That looks like all you'll need if i were you i would get new pivot balls and the covers they use, they are worth it.
