Need a 3s 4900mAh 20C lipo
mkrusedc
NeuMaxx
mkrusedc's Avatar
Need a 3s 4900mAh 20C lipo - 04.14.2008, 11:40 AM
Does anyone know where I can find two 3s 4900 mAh 20C lipos??
rschoi_75
Certified Spaceball
rschoi_75's Avatar
04.14.2008, 12:35 PM
Does it need to be exactly those specs or can it be similar?
The only one I've found is the FP Evo-20 4900. Here's a good resource page:
http://www.progressiverc.com/3S_Lipo.html
rcm xt8
rcm xb8
rcm crt.5
04.14.2008, 03:10 PM
http://www.visionhobbies.com/1675914.html
mkrusedc
NeuMaxx
mkrusedc's Avatar
04.14.2008, 11:34 PM
Is it ok to use a 20C 2s and a 25c 3s battery??
JerryF504
I don't understand, but I don't think I like it.
JerryF504's Avatar
04.14.2008, 11:54 PM
It's not recommended, but you could probably do it if you used a LVC on the 20c 2s pack, but I would probably use one on the 3s also, just to be safe. The LVC on your ESC wouldn't work because the 20c pack's voltage would drop more than the 25c pack.
mkrusedc
NeuMaxx
mkrusedc's Avatar
04.15.2008, 12:12 AM
Thanks Jerry. The only ones I have found are from MGM.
JerryF504
JerryF504's Avatar
04.15.2008, 02:25 AM
Novak has them also. Here is a link with the part numbers or you can buy them from the product details page.
mkrusedc
NeuMaxx
mkrusedc's Avatar
04.15.2008, 11:38 AM
Thanks I meant 20C 3s 4900mAh packs.
