Go Back   RC-Monster Forums > RC-Monster Area > Customer Testimonials and Feedback
6S CRT.5 Neu motor question
VintageMA
VintageMA's Avatar
6S CRT.5 Neu motor question - 04.22.2008, 12:10 PM
I've been reading that a 1506 should be fine to push a CRT.5 and a 1509 may be overkill. Looking to move from a 3S to a 6S setup to reduce amp draw and increase efficiency gearing for a modest 40mph - nothing crazy. Would like to keep the motor RPMs around 30-35K.
A few choices: (assuming quality LiPos holding 3.5v/cell under load - 6*3.5 = 21V)
1506/3Y 1850 = 38850 rpm
1509/2.5Y 1450 = 30450 rpm
So which do you think would run cooler with less amp spikes and overall draw?
The 1506 is a smaller motor and will draw less overall, but with a higher kv it may pull larger spikes trying to spin-up.
The 1509 will have more torque and a more mellow spin-up amp draw, but it's a larger motor and the added torque will come at the expense or more current.
I'm only getting 10 minutes run-time with 3S and a LMT 1930/6. Motor and esc cool, but lipos are touching 130*.
“Everyone has a right to be stupid; some people just abuse the privilege.”
