Nosediving Neus
Dafni
Dafni's Avatar
Nosediving Neus - 05.09.2008, 02:22 AM
Hey guys, just found out the other day that a direct drive conversion with a Neu motor requires a bit of throttle mid air to keep the nose up. Did you find the same?
Usually I use Lehners, they freewheel much smoother, and obviously the mid air controll is more similar to those of nitros.
Just curious if you found the same. Jumping wise, I like the Lehners (and even Feigaos) better.
Daf
