pinion gear from 7xl motor meshing on stock spur
blueb8llz
pinion gear from 7xl motor meshing on stock spur - 05.12.2008, 09:25 PM
i got my 5mm pinion from rcmonster and im using a stock traxxas 68t spur. but the teeth is not meshing right. like only half of the teeth is meshing onto the spur. is it suppose to be like this. i ordered the 5mm 24t pinion...but im not sure if rcm sent me the mod 1 5mm pinion. if they did. would it still mesh at all with my spur or no? im worried this is the wrong pinion and dont want to run my truck until i have this figured out....please help
the depth of the teeth on the pinion gear is filled up becuase the teeth on the spur gear is taller, but the teeth on the pinion gear is sooooo short...and its squarish instead of shape of a point...so only half of the spur gear teeth is being used...correct?
