COOKIES!
Battery (GP3300s) failing... -
09.13.2005, 02:58 AM
I run 14 cells GP3300s.
I charge them to 3600mAh, as that is what they peak too with the Great Planes Triton.
Lately, the runtime and power is alot worse with my Maxx, it could be that all this weight I am adding with allu' is slowing it down but I wouldn't of thought it would make that much of a difference.
My Triton can discharge and cycle (which I have never done before).
How could I increase the performance of them again? Can someone describe the basics of how to cycle your cells?
Thanks.
RC-Monster Custom
09.13.2005, 11:06 AM
Get a 20 amp discharger minimum, the triton can only do 3 which is a bit low to get the pack's up to life.
Then it's just charge, let them cool down and wait for a few hour's and then discharge. Repeat this step a few time's(like 5) and try again. No improvement? Try gearing a teeth or two down and see what happen's(actually do this before you buy new stuff).
At what amp rate do you charge your battery's?
COOKIES!
09.13.2005, 11:13 AM
Charge at 5A.
I sold my 15A discharger I had, as it toasted my other cells I had.
RC-Monster Custom
09.13.2005, 11:20 AM
Try chargeing at 4amp. I normally charge my gp's at 4,5 and they get not really hot but hot when they peak. When doing 4 amp's they are hand warm when they peak and seem to keep a much steadier(sp?) voltage/ ampage.
Alway's keep a close eye on battery's when charging/ discharging. I'm using a team corally digital discharger which doesn't like to discharge full battery's and nearly caught fire doing so. Now it's got a cpu fan strapped to the side to keep it cool and it's fine.
The discharger you where using must be broken. 15 amp discharge isn't anywhere near fatal for gp's, or the cell's where old and worn. But still I doubt that since the amp draw in a car/ truck is much higher.
COOKIES!
09.13.2005, 11:26 AM
My GPs don't get warm when charging to 3600mAh?
I charge 2 packs at once and normally one (that is connected straight to the charger rather than stacked) is warmer?
Should I charge until they are warm/hot? Ignoring what the Trition reads at?
RC-Monster Custom
09.13.2005, 11:50 AM
Try charging 1 pack at the time. Mayb it's false-peaking. Any pack should be warm'ish when charged full.
09.13.2005, 01:57 PM
If there is a difference in the individual packs it could produce a false peak. Are you connecting in parallel or series. If parallel it should go to 6600mah which may go beyond the limits of the triton( I use a pirrana digital peak and it goes to 5000mah) I'm not sure about series as i don't know the limits on the charger. I hope this helps
COOKIES!
09.14.2005, 02:45 AM
I have it like the image attached, where the other battery is stacked (connected) to the other batteries wires.
You shouldn't have to charge at 6600mAh, as no matter how many cells you have the capacity is always 3300mAh?
RC-Monster Custom
09.14.2005, 10:44 AM
I don't know how that should ever work properly. It simply can't, the charger can only detect if 1 pack is full, not 2.
Did you try charging 1 pack at a time at 4 amp's?
10.06.2005, 02:57 AM
I use a superbrain 959 and have 7 cell gp3300 packs and when i charge them they dont get very warm, maybe a slight rise in temperature but hardly anything. When i run my emaxx with two fully charged packs i get about 5mins run time, but thats 90% full throttle in first gear doing wheelies and donuts. Is this normal runtime for my batteries? or is my charger not charging them fully?
RC-Monster England!
10.06.2005, 06:09 PM
Whenever my GP3300's peak they're around 45C temperature (my cheap packs run closer to 50C). I detailed my charging methods in a recent thread I think.
So are you plugging the batteries like, + from one and + from the other go to the charger plus, and - from both batteries go to the charger negative? Or + from one battery goes to - on the other battery, and the unused + and - go to the charger? The first method is parallel, the second is series. In your car you run series, if you charge in parallel, your charger sees it as a 8.4v 6600mah battery, which it can't fully charge.
Charging in parallel or series with packs that aren't very well matched isn't a brilliant idea anyway, although it does work it slowly destroys the batteries, as one pack will fully charge before the other, so it'll either false peak and not give you full power, or one pack will overcharge causing damage.
Basketti: Batteries are always warm to touch if fully charged, due to the charging method, if yours are barely warm its a hard one to call. Can you adjust the delta peak value on the 959?
Whew, sorry for the long reply :)
10.06.2005, 06:30 PM
I can change the amps, and mV. whats delta peak voltage? Thanks
RC-Monster England!
10.06.2005, 06:34 PM
The delta peak voltage is what the mV is. Its the voltage drop the charger looks for, which tells it when the battery is fully charged. What mV value are you using?
10.06.2005, 06:35 PM
im using 40mV
RC-Monster England!
10.06.2005, 06:38 PM
Whats the lowest setting you can run? I use a 28mV cutoff on my 7 cell packs, and they come off nice and warm, but not toasty. 40mV means your charger should be cramming a bit more charge in than mine, so in theory, your cells should be coming off a bit warmer than mine.
Are any of the cells hotter than the rest?
