Sidewinder Micro and Mamba Micro Pro
jnev
jnev's Avatar
Sidewinder Micro and Mamba Micro Pro - 05.13.2008, 07:19 PM
Anyone know the difference between the Sidewinder Micro and Mamba Micro Pro? There is info on the sidewinder Micro, but nothing on the Mamba Micro Pro.
Any info would be appreciated.
BlackedOutREVO
05.16.2008, 12:43 AM
Well Someone on one18th has one, bottom of pg one, and pg 2 also
http://www.one18th.com/forums/showthread.php?t=57479
I guess the micro pro is 35 amp vrs 25
The hard case and heat sink sell it IMO though! You thinking of buying one? I might not do my Mongoose set up, and run a micro pro, with a NEU 1105
MTBikerTim
Yip Yip Yip...
MTBikerTim's Avatar
05.16.2008, 12:45 AM
I would love to put a neu in a 1/18th. They don't make a motor that small though to they?
BlackedOutREVO
05.16.2008, 12:49 AM
NEU 1105 as I said is the size that seems good
Check this vid out, I almost crapped myself over how much power it puts out!!!
http://www.rctech.net/forum/showthread.php?t=222045
The first link is lower quality, the 2 links a few post down are higher quality, you choose lol
MTBikerTim
Yip Yip Yip...
MTBikerTim's Avatar
05.16.2008, 01:09 AM
Will a 1105 fit in an rc18. I have a mini-t and am thinking of getting a rc18. The 1105 wouldn't fit in a mini-t that's for sure.
ren
ren's Avatar
05.16.2008, 01:28 PM
You might still consider the sidewinder micro. Mine is quite fast. My Sidewinder Micro and Neu1105/2Y (5200kv) on 19/41 gearing in my Vendetta ST is happy as a lark. I get ESC temps around 105 and Motor temps around 110. Very cool running, just be sure to use good batts though.
