uh o, bad battery?
Trick440
uh o, bad battery? - 05.19.2008, 08:43 PM
My battery or charger is messed up.
Its a 4s battery but when hooked up the the 4 cell slot the charger says no balancer is hooked up. If I plug it into the 3 cell slot it recognizes it but it only charges it for a few seconds and it says its done.
Did I mess my battery up? I drove it probably pretty low about 2 weeks ago. It didnt shut off or anything but I had about 30 minutes of run time on it. So it sat for 2 weeks in that condition... Do you think I ruined a cell? Its a new battery other than maybe 5 charges on it.
Maybe its just a pulled wire or something but everything looks fine.
What should I do?
MTBikerTim
Yip Yip Yip...
MTBikerTim's Avatar
05.19.2008, 09:02 PM
What charger do you have?
Trick440
05.19.2008, 09:12 PM
Hyperion 0610i.
I was searching and ya.. I think she is a dead cell. I also left the battery plugged in... apperently thats a no no. The ESC was off.
Whats a BEC? I seen that in a few posts but dont know what it means.
05.19.2008, 09:27 PM
What kind of battery is it? Brand?
A bec is a battery eliminator curcuit, basically it powers the rec and servos via the main battery, so you do not need to use and external rx pack.
You most likely pulled it down too low leaving it plugged in.
Sent you a pm too.
Trick440
05.19.2008, 09:40 PM
Ok confirmed dead. Plugged it into the ESC it blinked and chirped a dozen times then shut off. The Hyperion was able to read the 4 cells, it said 5.3v, it would not charge saying voltage to low on cell 1, or 4 .. it varied.
So this is a $150 lesson learned. I knew better... been busy lately, it thats any excuse.
Trick440
05.19.2008, 10:07 PM
So it sounds like if I get a BEC I can go higher than 4S on my Quark 125b. I was sticking with 4S because the quark recommends external rx pack if u go beyond 4s. So all I need is a BEC to go beyond 4s?
05.19.2008, 10:10 PM
I would run a bec if you go over 3s. The internal bec will put out quite a bit of heat, even with 3s. Get a cc bec and disable the internal bec by removing the red wire from the quark rec wire.
General concensus is that the quark is only good to 5s. I run a 125b on 6s in my hyper8 buggy, but it is not geared high, and the buggy is light. So less load on everything.
azjc
05.19.2008, 10:26 PM
I run a BEC on anything over 2s
