DIY Hardened gears
kona
DIY Hardened gears - 05.21.2008, 03:40 AM
I wanted to run 6mm bore mod1 pinions against a steel spur, but didn't like the idea of soft metal on metal. After just one run, I could see significant wear on the SDP-SI pinions. I did a little research and found this method of case hardening that works really well and is quite easy. The key is a powder called Kasenit and it cost about $11-12 (available from MSC or ENCO) for a 1 lbs can. 1 can will probably last a lifetime. Case hardening creates a very hard layer of high carbon steel on the outside of the part.
Here are the steps I did: (wear safety glasses!)
Materials needed:
Kasenit
propane torch
vise grips
water
nail
magnet
gear that you want to harden (remove set screw)
Use the nail and vise grips to hold the gear while you heat. Keep turning to heat evenly and heat it until it becomes cherry red. You can check the temp with a magnet. When steel is at hardening temp, it will be non-magnetic.
Dunk it in the powder and coat the gear with the powder. Heat it again and recoat a 2nd time. Then reheat until cherry red and the steel becomes non-magnetic. Keep that temp for about 1-2 minutes. Immediately dunk it into a jar of water and swish it around. Water will spray out (safety glasses!)! Most of the powder will fall off and you will be left with a hardened gear.
The gear will be a matte gray finish and seems to rust pretty easily. Coating it with some oil would probably prevent that. You can check the hardness by using a file. The file will 'bite' into unhardened steel and 'skip' off hardened steel. The whole process takes 5-10 minutes.
So far, the gears I've hardened are holding up really well and show little signs of wear. I've noticed even steel pinions on plastic spurs show wear, so hardening these would probably help too. Hope you find this useful.
