Rx Plug Mod / To Program The Mmm....
xtremelimits285
E8ight T
xtremelimits285's Avatar
Rx Plug Mod / To Program The Mmm.... - 06.13.2008, 10:34 AM
OK GUYS,
i was thinking of getting a rx plug(6" long wires) just like the one on the MMM , an splice into the MMM's rx wire and SODIER the other plug/wire to the MMM rx wire...
THAT WAY I DONT HAVE TOO KEEP UNPLUGING THE RX PLUG TO CHANGE SETTINGS ON THE MMM....an i wont need to open my losi's rx box every time i need to program my MMM.....
I think this is a mod alot of people can do/an will like...
What do u guys think???
Gary Antonietti #9
Losi 8ight T - Monster Mamba - Neu 1515 1y - MaxxAmps 3s/4s/5s 8000mah - Futaba 2.4GHz Tx/Rx 6EX - Futaba S9351 servo - 15/46t gearing
FTT3 -Mamba Max - 2s 8000mah
  Send a message via MSN to xtremelimits285
skellyo
skellyo's Avatar
06.13.2008, 10:40 AM
I'm not sure that will work since you're still backfeeding the signal wire on the Rx. The Castle Link probably won't be able to recognize the MMM.
JerryF504
I don't understand, but I don't think I like it.
JerryF504's Avatar
06.13.2008, 10:48 AM
I was thinking the same thing. You might do better to just run a small extension to the outside of your receiver box and just unplug it there.
VintageMA
VintageMA's Avatar
06.13.2008, 10:50 AM
^+1
That would be the easiest.
“Everyone has a right to be stupid; some people just abuse the privilege.”
06.13.2008, 10:52 AM
Yeah, the receiver output signals would be conflicting with the link signals. Even when "idle" the receiver is still outputting a signal (around 1.5ms pulses) and not just floating. Maybe use a micro single-pole/double-throw switch on the signal wire would work...
RBMike
RBMike's Avatar
06.13.2008, 01:55 PM
You could just use a 3 wire switch.
rabosi
06.13.2008, 02:13 PM
something like this could work, though I'm not sure what plug type is on the MMMhttp://www3.towerhobbies.com/cgi-bin...&I=LXL287&P=ML
DRIFT_BUGGY
DRIFT_BUGGY's Avatar
06.13.2008, 05:39 PM
I just made a little ext., just measure you long you require and get a ext as there are only about $5 and come in all different lengths
Losi 8ight
MMM V1 w/1.20
Airtronics MX3 2.4Ghz
TP 5S 5000mah
Neu 2.5D/F
bruce750i
bruce750i's Avatar
06.13.2008, 05:55 PM
yeah just an extension so you have a place to tap into. Same problem with traxxas waterproof Rx boxes.
