Help with 0606I -
06.15.2008, 02:17 AM
I am using a Hyperion EOS0606I charger to charge my 5S 5000. It says that the charger chargers at 1C so I set the charger at 4000 (as I want it to charge at 4amps) and set it to 5S. I also am balancing the batteries and then while charging it comes up as LP+2.49A and as charging is going it eventually goes down to .41A when fully charged. Shouldn't it be charging a 4A? Or becuase I balance it at the same time it doesn't charge at 1C?
Losi 8ight
MMM V1 w/1.20
Airtronics MX3 2.4Ghz
TP 5S 5000mah
Neu 2.5D/F
