Novak SLYDR BL Kit & Sentry Data Logger
DRIFT_BUGGY
DRIFT_BUGGY's Avatar
Exclamation Novak SLYDR BL Kit & Sentry Data Logger - 07.02.2008, 06:36 AM
With input from the top drifters of the world, Novak has developed the specially designed SLYDR Brushless Drift System (#3066-3068). This system includes the new SLYDR Brushless Drift ESC (#1712) factory-wired to one of three, new Novak Drift-Spec Brushless Motors (#3466-3468). These 540-size sensored brushless motors include the Novak 13mm Neodymium Sintered rotor for improved initial throttle response and natural drag brake. The SLYDR Drift ESC, which is based on Novak’s GTB, contains new brake adjustments and features to help fine tune brake response, as well as all new throttle curve adjustments to further customize the already-smooth throttle response.
Novak has a product that gives you an in depth, close-up look into how your car is performing. Keep an eye out for the Novak-exclusive Sentry Data Logger. Simply plug it in, and the Data Logger will measure and record information from several **tiny sensors placed in your R/C car. The Sentry stores the collected data to be later reviewed on your personal computer. The Sentry’s small size and weight allow it to fit easily inside any R/C car. The Data Logger also operates on very low voltage, so R/C cars can drive like it’s not even there!
Losi 8ight
MMM V1 w/1.20
Airtronics MX3 2.4Ghz
TP 5S 5000mah
Neu 2.5D/F
