52mph Medusa 2000 Erevo 4s video
asheck
52mph Medusa 2000 Erevo 4s video - 07.15.2008, 05:19 PM
http://www.youtube.com/watch?v=Ji69qIoh37Y Thought I'd post this since I felt it was very impressive.All stock except electronics.I was running SPC 8000mah lipos geared 24/54 .I had to see what the motor and cells could pull.It still had alot of torque and didn't heat up to much.I kept it short though in 5 minutes of running hard the motor was 117 and the batteries were 85 thats with it about 75 out. Would someone else like to try to figure this out with the speed calculator?Because either this motor is off in the rating,The battery is holding 16+ volts under load,or I'm an idiot and doing something wrong with the calculator.
azjc
07.16.2008, 04:17 AM
try running it for a full pack instead of just 5 mins and instead of the street try taking it to a footaball/baseball field in short grass and report back.....
hoovhartid
Monster Bottle Opener
hoovhartid's Avatar
07.16.2008, 05:48 AM
Differential Ratio: 2.8461538461538462
Transmission Ratio: 1.8333333333333334
Other Ratio: 1
Spur Tooth Count: 54
Pinion Tooth Count: 24
Total Voltage: 14.8
Motor KV: 2000
Tire Diameter (inches): 5.9
Tire Ballooning (inches): 1
Motor Current Draw: 105
Motor coil Ω: 0.006
Spur/Pinion Ratio: 2.25 : 1
Total Ratio: 11.74038 : 1
Tire Circumference (inches): 24.82 inches (630.39 mm)
Total Motor Speed: 28340 RPM
Vehicle Speed: 56.73 mph (91.13 km/h)
Estimated Adjusted Speed: 52 mph (84 km/h) - 8% loss
Effective KV Value: 1914.86
KT constant: 0.68 oz-in/A
Motor Torque: 0.37 ft-lbs
Final Torque: 4.34 ft-lbs
Final Power: 1554 watts (2.1 HP)
Where did you go wrong? Tire size? Ballooning Amount?
just messin with ya. Its a nice set-up man
tc3_racer_001
tc3_racer_001's Avatar
07.16.2008, 06:08 AM
1 inch balooning does seem an awful lot. but damn thats fast! nice job :)
hyper 8.5 pro SOLD!
Monster Max Still Working...
JR SX3
Neu 1512 2D/S
12t pinion
4800 zippy-r
XRAY xt8
MMM
Neu 1512 3D/F
11t pinion
asheck
07.16.2008, 07:48 AM
I just geared like that to see how fast it would go with my highest gearing.Normally I run 24/68 and pull 46 mph,but can run that gearing as much as I want.I have a weak esc ,Quark 80b,that tends to start thermaling after awhile of running hard.I have added caps and done some heat modding,but it's just not quite enough.So I really can't push the motor to it's limits with that esc.
Yeah since the ballooning amount is radius,I normally just add a 1/2 inch.
sikeston34m
sikeston34m's Avatar
07.16.2008, 08:15 AM
Is everyone out of stock on these motors?
Where can I get one?
Thanks
George16
Supermaxx
George16's Avatar
07.16.2008, 08:34 AM
Thanks
I just sold my new Medusa motor last week since I already have a Neu. Where were you during that time ?
Predator with OS .21TM
Supermaxx with Mach .26
Revo with OS .18TZ
Kyosho ST-RR Conversion
Larrydino
Larrydino's Avatar
07.18.2008, 11:38 AM
thats a great video...good PR for Medusa
bustitup
07.18.2008, 05:24 PM
Funny you should mention pr....I called Jeff at medusa today to ask when the 70 and 80mm would be ready and he told me sometime in September....I told him that I would keep my 36-60-2000 then and just move it to another truck when the 70 is available.....he then asked would I give him some feedback on how the 36-60 performs and i told him there's a guy in the forums named asheck and his erevo with the 36-60 does a standing still back flip on to its wheels....he was so excited and amazed that he wanted to see this feat of torque envy...I'm going to link the video to him
asheck
07.18.2008, 05:54 PM
I just called Jeff,he's a good guy.I'm betting the bigger motors are gonna be monsters.(insert evil laugh here)
bustitup
07.18.2008, 05:56 PM
did you tell him you would get him the video?...if you did I wont bother
asheck
07.18.2008, 07:16 PM
yes I did.
