my mm and mmm problem
q8-maxx
E-Maxx Lover
q8-maxx's Avatar
my mm and mmm problem - 07.16.2008, 10:30 AM
hello,
I have:
mmm + neu1515 1y + 16 cell nimh + e-maxx
mm 5700 + 12 cell + rustler
when I push full throtle there are to slow to go back for normal so now has slow response not like before
Its don't want stop untel hit the wall Its very slow response I broke my emaxx and rustler bumpers
this problem doesn't exits in old frimware
What do you think?
07.16.2008, 10:33 AM
Have you reset your end points after changing the software version?
q8-maxx
E-Maxx Lover
q8-maxx's Avatar
07.16.2008, 10:41 AM
Sure I re program them everytime I update from pc
bruce750i
bruce750i's Avatar
07.16.2008, 11:56 AM
How about calibrating Mambas to your radio?
q8-maxx
E-Maxx Lover
q8-maxx's Avatar
07.16.2008, 12:18 PM
I do that for my futaba 2.4 and my stock radio and the problem still here.
Is it Possible the reason of my problem is my batteries?
Pdelcast
Pdelcast's Avatar
07.16.2008, 02:15 PM
Yes, it is possible. IF your batteries can't produce enough current for the motor, the ESC is forced to slow the throttle ramp rate, to keep the voltage from dropping too much (don't want a BEC dropout to cause a loss of control!)
What you will see is a sluggish throttle -- you pull full throttle, and the ESC will not go to full throttle until the battery voltage recovers, and this can be a noticeable delay if your batteries are not strong enough to drive the motor.
Patrick
Patrick del Castillo
President, Principle Engineer
q8-maxx
E-Maxx Lover
q8-maxx's Avatar
07.16.2008, 02:43 PM
That's exactly what I was thinking because my batteries was not full charged and one year old
Thank u Patrick
07.16.2008, 02:44 PM
I get a similar thing that happens to my Slash. Currently running 7 GP3300 cells on the MM/5700 motor combo, geared stock. MM settings are: low start power, 60% punch control, 20% drag brake, lowest timing, reverse lockout, no LVC, and throttle/brake are at default (I use the expo settings on the radio). Radio is Spektrum DX3r.
Granted, I know the 5700 is a very poor choice, but it's the only extra motor I had lying around. Temps after a run are quite hot on the motor, and ESC is warmer than I like.
What happens to me is: I gently pull the trigger. The truck starts to move, but then it acts like it goes by itself for a second or two no matter what the trigger is set to. Not a big deal as I soon plan to run 4s on a MedUsa 50 series motor (around 2500kv).
bl-is-future
bl-is-future's Avatar
07.16.2008, 02:45 PM
That was my very first thought, (batteries) but you said it was fine before firmware update so i assumed you ran the same batteries and did not post.
q8-maxx
E-Maxx Lover
q8-maxx's Avatar
07.16.2008, 03:15 PM
hey bl-is-future I'm sorry I did not explain my problem very clear. it was fine before update because the batteries was full charged
BrianG same here lol but I broke my front bumper its not problem I have new one
07.16.2008, 03:18 PM
Hmm. I might get a chance to play with some settings tonight or tomorrow. The only thing I'm going to try is increasing the start power. If that doesn't help, I might go back a firmware version or two with the same ESC settings and see what happens. I'm not using a slotted stator motor, so using older firmware won't affect me too much.
bdebde
That's All Folks!
bdebde's Avatar
07.16.2008, 03:19 PM
Charge the battery!
bl-is-future
07.16.2008, 03:20 PM
only time i have ever had a problem like this is with bad batteries and/or radio interference.
07.16.2008, 03:28 PM
Sadly they only do a 3300 or a 2200 50mm
q8-maxx
E-Maxx Lover
q8-maxx's Avatar
07.16.2008, 03:44 PM
nice I will wait your result, maybe the firmware effects
