4s in a buggy
Fast5sRevo88
4s in a buggy - 07.16.2008, 02:49 PM
What is the largest capacity(Mah) 4s lipo that will fit under the body of a buggy, 4s 6000mah, larger, smaller?
DRIFT_BUGGY
DRIFT_BUGGY's Avatar
07.16.2008, 06:01 PM
Different brand lipos have different sizes. I am running a TP 5S 5000 - Dimensions (WxLxH): 42x48x160mm and it is just to big, makes the side of the body sit up abit
Losi 8ight
MMM V1 w/1.20
Airtronics MX3 2.4Ghz
TP 5S 5000mah
Neu 2.5D/F
07.16.2008, 06:43 PM
Also depends on layout. If you split it into two 2s packs and put them on either side, you can fit higher capacity packs. Of course, this limits motor placement. Also, you can raise the body a bit if running really close.
bl-is-future
bl-is-future's Avatar
07.16.2008, 08:14 PM
i can fit 2 4s 5000mah Maxamps on my hyper 7. Granted i dont do this but they will fit. BTW this is a perfect fit. Doent push the body up at all but there is no room left for another cell.
Fast5sRevo88
07.16.2008, 08:34 PM
Would 32mm high work?
TDC57
TDC57's Avatar
07.17.2008, 02:55 AM
the largest one i can fit in my 808 is 4s, 4500mAH with the tray, battery and strap it = 41mm and i have 43mm until the body is lifted.
hope that helps (??)
Nothing!.. Hahahahaaa..
