Originally Posted by lincpimp
I figured the esc was sending some sort of screwed up signal down the signal wires. I would test the componets one at a time with a different radio setup. What are you currently using for a radio?
Futaba 3pks I was using an HRS receiver with the first two servos but I switched it out for a standard fm on the last one. I tried everything with different radio gear and still the esc won't respond. The bec only has + and - wires, no signal. Even if the bec sent full battery power to the radio the esc should be ok. Unless it sent + voltage down the - wire
