92 degrees air temp, 40 minute run until I got tired of standing in the heat. The pack delivered solidly, voltage was 14.7v with a .06 gap after 40 mins. Pack temp 101, motor 125, esc 127. The power delivery was on par with the trc paks. The truck drove better being 500 grams lighter on the right side. The TRC packs never got over ambient temp is a difference, but I'll take 101 in 92 degree heat after 40 mins. I look forward to getting a few cycles into them.
The pack has been charged and run 4 times now. The 4th run was the 1st time I took it all the way to lvc at 45 minutes of speed runs in sand and hardpack and some donuts at a construction site. It has not gone over 106 degrees and delivers solidly right down to lvc. I have no eagle tree, sorry.
It just took 5348 back into it, cells were at 3.06, 3.09, 3.09, 3.1 starting charge.
on par? i would have thought the neus would deliver a noticalble difference in power.
Blue the power delivery is about the same, the weight difference is noticeable in the handling.
Linc, it is in a converted revo, rc-m mount, tekno battery tray and esc mount, geared 17/38, 17mm adapters and crime fighter lpr's. Until I get my MMM back I am using an MM + ubec + fan. and JR ds8611a steering servo. 10.1 lbs with desert rat body on.
I also have a set of the LPR Crimefighters that I run in addition to the Maximzer Beadlock/Badland combo...what i like about the LPRs is they have the least amount of balloning of any combo I have run...the Badlands balloon a lot...
