Bidproducts 125a esc?
Pedebeater
Pedebeater's Avatar
Bidproducts 125a esc? - 07.21.2008, 09:52 PM
I think I will be buying and testing this esc for my truggy project. It is so cheap I don't see how I can go wrong. I was wondering if anyone had any more info on this. Anything is greatly appreciated, thank you.
http://www.bidproduct.com/part/Produ...20ESC_117.html
Faster than a cheetah on cocaine
  Send a message via AIM to Pedebeater
hemiblas
hemiblas's Avatar
07.21.2008, 09:56 PM
I dont see a price, but I would save up your money for a single good controller and go that route. I had a bunch of 80A esc like that and they melted. Its better to get a good one with a warranty and then you dont have to worry. You dont want to be the first one to try something new only to find it doesnt work.
07.21.2008, 10:39 PM
The price is $34, it's at the very right of the page. Stupid location for the price IMO.
Pedebeater
Pedebeater's Avatar
07.21.2008, 11:03 PM
I still think I will give it a try. Get me running while saving for the godly MMM. lol
lutach
lutach's Avatar
07.21.2008, 11:58 PM
You will need to use mechanical brakes with the airplane controlelrs. If those are the same as the Himodel unit, it might work with a pistol radio without the pistix.
Pedebeater
Pedebeater's Avatar
07.22.2008, 12:26 PM
I was thinking about the whole machanical brakes thing and was hoping you could help me out a little with it. From what I was told I need to make a j-harness, to plug the esc and brake servo into the same channel. Now I don't understand how the servo is going to apply brake when I put brake on with the transmitter. How do they get synchronized with th esc?
Thank you,
PB
MetalMan
MetalMan's Avatar
07.22.2008, 12:40 PM
A Y-harness is one way to go. It would actuate brakes the same way as if there were no Y-harness.
Another way to go is channel mixing, if your radio is good enough. For example, on my Nomadio React I have channel 2 for throttle and I set up channel 3 for the brake servo for my Savage and buggy. Moving the trigger will actuate either the brake or forward throttle, since I set up the brake so that it has no throw when forward throttle is inputted.
Pedebeater
Pedebeater's Avatar
07.22.2008, 12:44 PM
I doubt my radio has that feature, but I will check. I am using a Airtronics mx-3s. The only thing that was keeping me from the 200amp esc was the listed dimensions, but it looks to be the same size just double stacked boards, so I might give it a try.
http://www.bidproduct.com/part/Produ...20ESC_118.html
lutach
lutach's Avatar
07.22.2008, 12:52 PM
You will disable the ESC brakes to start with. The Y harness is ideal if you don't have a digital radio that has the channel mixing option. It's fairly simple the way it works. It's the same way it would work if you had it as a nitro.
Pedebeater
Pedebeater's Avatar
07.22.2008, 12:53 PM
Ok thank you. My radio is digital, but doesn't have all features.
lutach
lutach's Avatar
07.22.2008, 12:55 PM
Just go with the Y harness and it will work.
