which Neu 1515 has the most torque/power?
ReV:-O
RC-Monster Carbon Fibre
which Neu 1515 has the most torque/power? - 08.15.2008, 07:22 AM
hi guys,
as the title says, im wondering which Neu 1515 has the most torque/power? the Neu 1515/1y seems like the most sensible one, but it has a fairly high kv rating, so i'm wondering if the 1515/2.5D is a little more powerful...
anyway what do you guys think?
tc3_racer_001
tc3_racer_001's Avatar
08.15.2008, 07:42 AM
on what voltage in what truck? need more information. without voltage and application this is a useless thread...
hyper 8.5 pro SOLD!
Monster Max Still Working...
JR SX3
Neu 1512 2D/S
12t pinion
4800 zippy-r
XRAY xt8
MMM
Neu 1512 3D/F
11t pinion
ReV:-O
08.15.2008, 07:45 AM
o right sorry in a losi muggy, MMM, and Poly RC 6000mAh 6s lipo
bl-is-future
bl-is-future's Avatar
08.15.2008, 08:47 AM
you already have another thread on this!
Byte
08.15.2008, 11:13 AM
I think 1515/1Y
08.15.2008, 11:34 AM
6S 2.5DF I would go for or even lower kv...
ReV:-O
08.15.2008, 01:29 PM
yeah lol i planned to get a Neu 1521 motor but they dont have a flat spot on the shaft and i dont know how to make one myself. but i could buy a 1515 from tekno rc which already has one
bensf
08.15.2008, 01:51 PM
Just use a file or a dremel to make the flat spot. Its really easy and shouldn't stop you from getting the bigger motor.
ReV:-O
08.15.2008, 02:11 PM
i dont have a dremel but i'm sure i could find a file. but how could you file it because the shaft moves (it turns)?
08.15.2008, 02:41 PM
Two hands! Err a pair of pliers in one hand and a file in the other?
ReV:-O
08.15.2008, 03:03 PM
yeah but how can you clamp the shaft? lol its so small
08.15.2008, 03:43 PM
Clamp the tip of the shaft in a vice, then file away with a narrow flat file. Once that section is done (doesnt have to be a big flat spot going half way through the shaft), just finish up the tip by holding the flat spot with some pliers, and work away on the tip until it mathces the rest of the flat spot. Common sense and iniative really.
All the average RCer neads is:
bench and small vice
dremel or similar rotary tool
cordless drill
selection of drill bits
seletion of files- large and small
hammer and center-punch
hacksaw
Thats all I have, and I can custom fab varies things like a new chassis plate, and new motor mounts.
brushlessboy16
brushlessboy16's Avatar
08.15.2008, 03:59 PM
i have:
drill press
Dremel
Hack saw
Recip saw
Jigsaw
assorted drill bits and countersinks
assorted punches and files
assorted screwdrivers and hex wrenches
12ton press
welder
bench grinder
08.15.2008, 04:10 PM
But no metric drill bits - ;)
brushlessboy16
08.15.2008, 04:12 PM
did you really have to go there
