Sidewinder 1/10 ESC Questions
Frozen72
Sidewinder 1/10 ESC Questions - 08.16.2008, 12:40 PM
Is the Sidewinder capable of 4 A123 cells? (That would be 13.2 volts) I would be using it with a Ammo 28-35-3900 in my Vendetta ST(1/18). I would only use it for speed runs and if needed I could get a fan for the ESC.
Nicholas
Semi Pro
Semi Pro's Avatar
08.16.2008, 02:18 PM
isnt that way over the max rpm of that motor?
Takedown
WARNING: May become violent.
Takedown's Avatar
08.16.2008, 03:36 PM
A couple people have ran the SW on 4s w/o issues.
RIP- Tammy (9/14/08)
DLS II
08.16.2008, 03:41 PM
On the high side it's rated for 3s lipo(11.1) and 12 cell nimh(14.4). 4s A123 will drop down to 12v under load. At the load level you want to run you should be ok. I have a question of my own, will the sidewinder(1/10) handle 4 cell nimh (4.8v)? I set up my KX1 with a Feigao 13t and a 4.8 volt nimh pack and it wants to cog after it has started to accelerate. The FDR is 4.5 to one. Don
Frozen72
08.16.2008, 04:22 PM
The Ammo 28-35-3900 has a max rpm of 60000 rpm. With a 4 cell A123 it would be just over 51000 rpm.
