I did a small test today w/a mmm and MGM esc -
08.16.2008, 07:12 PM
I tested each esc w/2 batts. After a full battery....20min
I borrowed a friend's mmm esc. & ccbec.
Motor was allowed to cool between batteries.
set up:
9xl 44/17
4800 4s 25c
MMM esc & MGM 160 esc
I used forward and reverse on both controllers.
Temps:
Batts: 140
mmm 150
9xl 170
timing 2*
punch control 50%
low start power
cc bec 6v
brake 50%
drag brake 30%
Temps:
Batts: 115
MGM 120
9xl 130
timing 5*
accel. .66
brakes 1/1.3
behavior when batt. goes down... cut off
correction of neutral NO
I found it interesting that two setups which are similar can yield way different temps.
