Ofna Ultra GTP Conversion!
Ofna Ultra GTP Conversion! - 08.20.2008, 05:03 PM
So, my next project begins.
I just got home from the LHS, ordered the Ultra GTP kit as well as the Porsche 911 body for it!
I can't pick them up until next monday or tuesday though because I'm taking a trip with my dad.
I'm going to run my Hacker C-50Maxx, MM, and 5s with a TrueRC BEC. Also going to run a HS-645MG (oddly I have them in all of my projects)
Gearing will be about 14/45 (58mph)
Calculated:
Differential Ratio: 3.142857142857143
Transmission Ratio: 1
Other Ratio: 1
Spur Tooth Count: 45
Pinion Tooth Count: 14
Total Voltage: 18.5
Motor KV: 3033
Tire Diameter (inches): 3.8
Tire Ballooning (inches): 0
Motor Current Draw: 0
Motor coil Ω: 0
Spur/Pinion Ratio: 3.21 : 1
Total Ratio: 10.10204 : 1
Tire Circumference (inches): 11.94 inches (303.23 mm)
Total Motor Speed: 56110.5 RPM
Vehicle Speed: 62.79 mph (100.87 km/h)
Estimated Adjusted Speed: 57 mph (92 km/h) - 9% loss
Effective KV Value: 3033
KT constant: 0.45 oz-in/A
Final Torque: Amperage not specified...
Final Power: Amperage not specified...
08.20.2008, 05:05 PM
Does it have the spool or the diff? I'm running the spool and trying to find something smaller that 51!
08.20.2008, 05:08 PM
It's got the spool. Does that mean I have a 51t spur? Do I have to change anything about my plan?
What's_nitro?
Soldermaster Extraordinaire
What's_nitro?'s Avatar
08.20.2008, 05:15 PM
Arkt1k: SDP-SI is where I got mine. Sort them for M1, Acetal w/Brass insert, Hub w/SS, 8mm bore size.
BL_RV0: Are you gonna run foams? The stock tires will balloon a little bit. I noticed it was set to 0 in the calc. The GTP kits are very nice. BrianG, B4Maz, and myself are also working on conversions. Good luck with yours!
08.20.2008, 05:22 PM
I have one to and will post up - yes it is 51...
I ran at the w/e with a Hacker B50 7XL 4s geared 22/51 and it was recorded consistently at 48mph/50mph on the radar...
How well does that spur hold up?
08.20.2008, 05:35 PM
I would not run the c50 maxx over 4s if I were you...
Mine ran nicely in a hyper7 on 4s. Had it geared 11/46 and it ran cool, and did around 40mph.
08.20.2008, 08:24 PM
Not going to run foams. Forgot about the ballooning, but I figure it won't make much of a difference.
I should be asking you, did you have any problems?
Sadly, I don't have the funds for a 4s pack, and couldn't bear to sell the Hacker, so that's why I chose an onroad. Takedown ran the Hacker in a Matrix truggy on 5s and he said it did fine- in a TRUGGY!
I'm sure it'll do alright in the onroad.
08.20.2008, 08:47 PM
Ordered from Mike:
Ultra GTP Mount
Bore reducer
16t pinion
08.26.2008, 09:39 PM
Got the GTP, and the stuff came from Mike!
Got all the nitro stuff removed, installed the RCM mount and pinion, along with the C50-Maxx.
Pics:
brushlessboy16
brushlessboy16's Avatar
08.26.2008, 09:43 PM
sweet!
gimpygolden
gimpygolden's Avatar
08.26.2008, 10:42 PM
Make sure you shim you fr and rr diffs. My rear ring and pinion is getting a little clicky.
"If yer not 1st,yer last"
OFNA GTP w/Quark-Medusa 60mm-5s
Inferno SP2 w/MMM-1512 2.5d-5S
Inferno St-rr w/MMM-1515 1y-5s
08.26.2008, 10:50 PM
Very true, Hongnor k series diffs (most ofna vehicles save for the hyper line) are not the best, and require a good shim job...
gimpygolden
08.26.2008, 11:06 PM
By the way I run 8xl on 5s 22 tooth pin on foams and it is retarded. I usually set EPA to 85% (140% is max) still hard to control.Have fun
Takedown
WARNING: May become violent.
Takedown's Avatar
08.26.2008, 11:18 PM
Looks like a fun project RV0. I never had any issues with the hacker when I ran it on 5s.
RIP- Tammy (9/14/08)
Takedown
Takedown's Avatar
08.26.2008, 11:19 PM
Also will this be made into a rally kit. Onroad's arent to exciting IMO because all you can do is street driving. Atleast when your rally converted you can go offroad somewhat.
