Anyone know what Hyper center diff this is?
e-mikey
Anyone know what Hyper center diff this is? - 08.24.2008, 12:05 PM
I have (I think) an hyper 8 or 8.5, not sure which one. Can anyone tell me if this is the center diff from the 8 or 8.5?
brushlessboy16
brushlessboy16's Avatar
08.24.2008, 12:10 PM
the correct answer is yes- they both use the same center diff- where are those measurements mike ;)
MetalMan
MetalMan's Avatar
08.24.2008, 08:21 PM
That would most likely be 8.5. The Hyper 8 Pro doesn't have the aluminum plate below the center bulkheads, and the chassis has some inscription that I think might indicate the extension of it over the original Hyper 8 chassis.
brushlessboy16
08.24.2008, 08:40 PM
it does say +2 on the cutout under the motor, indicating that its an 8.5
metalman is right
e-mikey
08.24.2008, 08:48 PM
Thanks..
So what parts would I need to make Mikes motor mount fit?
Finnster
KillaHurtz
Finnster's Avatar
08.24.2008, 09:10 PM
Just the mount I think. I have a hyper ST, and the mount goes right on top of the plate. The only thing is the posts are recessed into the chassis plate on this, so IDK if the mount would be too tall....
