ii boughta MMM v1 when it first came out and i am about to put 2 x3s lipos (6s) through a medusa 60mm 1600kv motor. what precautions and mods do i need to do to the MMM and how many have done this with success.
thanks for the help
The bec is completly hit or miss - You can protect the fan with a teflon washer and the bottom fan connection by dremeling the case - See JHautz mod thread.
That said some ppl have been lucky and run theirs for hours with no issue
Where does the teflon washer go? Between the fan and the case? And I have not been able to find the jhautz mod thread, any chance of a link? Please!!!
i also read over the many threads and forums:
1- no switch
2- do not use MMM BEC use a receiver pack
3- plug fan into receiver or alternate power source not MMM
let's build something sick!
Reason: mistype
1- no switch
2- do not use MMM BEC or receiver pack
Just run it as it came out of the box, if it dies, castle will take care of you. In the meantime you can run your MGM while you wait. What, you don't have a MGM for back up? (I do)
One more shot of how I pocketed some of the material out of the MMM case bottom so the fan plug and the other black component dont rub on the case. I just used a dremel and a flat bottomed bit.
