Can 2 2s batterys be charged in series?
e-mikey
Can 2 2s batterys be charged in series? - 08.29.2008, 06:10 PM
My buddy has 2 - 2s 5000mah lipos. Can he connect them in series to charge them both?
Follow up... Would he charge them at 5amps?
asheck
08.29.2008, 06:19 PM
You can,but if you haven't kept them balanced to each other from the start it could get risky.If they don't have the same voltage before they start 1 will get overcharged.But if you start with 2 charged packs then run them in series you should be able to charge in series.It would then be a 4s 5000mah pack.So it would charge at 5 amp
Patrick
Patrick's Avatar
08.30.2008, 01:55 AM
This should help with wiring. http://www.scriptasylum.com/rc_speed/_lipo.html
I would only do it though if the packs are fairly close in age and use, and if they're being run together. Don't do it if there being used separately in a 2s vehicle, then connected together to charge, they will be too far out of balance.
