Yes. The Turnigy controllers are a great value. I have the HV version of that one, as do a few other members. The only thing I recommend is that you also pick up the programming card as the Tx programming is a POS
. They are very smooth with starting/running unless you gear extremely high. The controller has no BEC, so you will need a UBEC circuit or a Rx pack. Also, the controller does not support motor braking in land-based vehicles. Your car/truck will need to have mechanical brakes; that is, if you're using it in a car/truck...
