MM on 5s truggy
CRTIM
MM on 5s truggy - 09.01.2008, 08:12 PM
just curious and would appreciate some help ....i am in the middle of a CRT X1 truggy conversion ,my set up is ...Nue 1515/2.5/f and MMM v2 on 5s...if when i finish it and my MMM fails(which it sounds like it will ) can i use my MM from one of my crawlers as a back up as long as i use a fan and bec....on 5s and would it be a reliable set up ??....i ask this because i'm afraid to spend any more money on this conversion and not be able to run it till CC figures out the MMM problem (if they even can )...thanks for the time and any help
VintageMA
VintageMA's Avatar
09.01.2008, 08:20 PM
I'm running 5S in a model pulling around 1000 watts. You're going to be pulling a lot more power (probably close to 1700 watts peak) not sure the MM would handle it - but it's definitely a trooper.
I run a small fan on the top of mine and find that's all I really need to do. Absolutely no temp problems.
Only issue I have is that pack can't quite be at full voltage or else the MM will initialize but as soon as you pull the throtle it'll cut out. Since I have 2 fans running in the model with the 5S MM along with the CC BEC, I just let them run a few minutes to drain the battery a touch and the power-up the MM and I have no problems.
Hopefully someone can speak to how a 5S MM will handle that much power.
“Everyone has a right to be stupid; some people just abuse the privilege.”
bdebde
That's All Folks!
bdebde's Avatar
09.01.2008, 08:22 PM
many have had good luck with it on 5s others not. there is a thread about it around somewhere
kevin23
09.01.2008, 08:26 PM
I run 5s on a mm in my 8 buggy with a 1512 2.5d.
no problem's with mine whatsoever,has been awesome to date,with around 3 hours of track time on it
gimpygolden
gimpygolden's Avatar
09.01.2008, 08:48 PM
Same as above,runs great.
Just for extra insurance I added 25mm fan and an Novak HV cap
"If yer not 1st,yer last"
OFNA GTP w/Quark-Medusa 60mm-5s
Inferno SP2 w/MMM-1512 2.5d-5S
Inferno St-rr w/MMM-1515 1y-5s
CRTIM
09.01.2008, 08:56 PM
thanks guys for the replies...i guess i can just hope my MMM works ...
would 4s work better with the MM in the same set up ??(1515 2.5d in the 1/8th truuggy)
coolrunnings
09.01.2008, 09:25 PM
I would not run an mm on 5s not even if I had to. They do work fantasticly on 4s mine is on 4s at about 110deg with fan on a 70deg day.
kevin23
09.02.2008, 01:07 AM
my mm on a regular 90 degree day here in florida has never seen over 120 even after 20 min straight of track racing.
Forgot to add that I added a novak cap to mine
