Hyperion 0610i with LBA10???
z1nonly
Hyperion 0610i with LBA10??? - 09.02.2008, 09:44 AM
Hi, I hope someone from here can help me out.
I was wondering if it was possible to use just one 0610i Net charger to charge 2 separate but similar battery packs with the use of the LBA10 balancer?
azjc
09.02.2008, 11:03 AM
the 0610i already has the lb10 balancer builtin and it will only charge 1 pack at a time
09.02.2008, 11:11 AM
Well actually yes but really must be the same cells with a similar number of cycles...
You could make a series or parallel balancer harness to match your requirements - Perhaps post up exactly what you are trying to do.
Rgds
z1nonly
09.02.2008, 11:04 PM
I have 2 electric cars with the same setup, but I only have one charger. What I would like to do is charge 2 4000mah lipos that are of the same brand with this charger. It wouldn't matter to me if they were charged in series or in parallel. If this is possible, I would also use it to charge 2 battery packs for an E-Revo.
I know the LBA10s can be linked together as Master and Slave to charge 2 separate but similar batteries, but can it be done with the 0610i Net's internal LBA10 balancer?
