Quick Sidewinder ? and Motor KV -
09.09.2008, 01:22 AM
The chart that CC has for the mm and sidewinder has a limit for the SW 3s on thier cms4600 motor. So it should be fine to run 3s on any motors under that KV?
Say a Novak HV6.5 which I think is 3000kv or the medusa 36-50-3300. The Novak HV4.5 is at 5000 so that would be a no no?
Just curious is it becuase the higher KV motors will draw more amps or volts then the sidewinder is rated for?
Thanks.
