Need two more minutes.
FG101C
Need two more minutes. - 09.21.2008, 02:18 AM
Hi guys, I have a question. I raced tonight, did pretty good, truck felt great. The main is twenty minutes, as soon as "two minutes left" was called the Auto LiPo setting in my MMM kicked in. I seemed to have gotten more run time when I had the cutoff set to 12.8 volts, but I thought I read that with the MMM v2's the problem alot of people are having has to do with custom LiPo cutoff settings. That's why I put it on auto-LiPo.
So my question is how can I squeeze two more minutes run time out of it?
Losi 8ight-T, stock drivetrain (48 tooth spur).
MMM, 100% punch control, Lowest (0) motor timing.
Polyquest 6000mah 20c 4s pack.
11 tooth mod-1 pinion.
Tekno Neu 1515 1/Y/F motor.
The track was somewhat dry and pretty loose, I did get a little too throttle happy a few times which might be the two minutes right there. I was wondering if going to a 10 tooth pinion might get it to, or would it be better to go with the 50 tooth spur gear?
Thanks for any help with this.
FG101C
09.21.2008, 01:34 PM
Updated the MMM firmware to v1.19, set the lipo cutoff at 12.8v. Ordered a 10 tooth pinion from Mike. This, and a calmer throttle finger will probably get the two minutes I need.
