Slayer -> Revo
xcntrk
xcntrk's Avatar
Slayer -> Revo - 09.21.2008, 08:22 PM
So I’ve had it with my new E-slayer. The suspension on this thing is terrible when coupled with the narrow wheelbase (vid). I’ve tried everything from sways, springs, new tires/wheels, etc, and am ready to cut my losses…
So short of down-right selling off this rig; I figured I could at least turn it into a capable Revo. Anybody know what parts would be needed to make the transition? I’m thinking F&R upper & lower suspension arms, new pushrods, steering links, and each wheel drive-axle shaft. Anybody know if the bulkhead mounting points are compatible, and the knuckles?
Lastly; anybody looking for a nice set of Slayer arms/shaft/etc? up for trade?
Tmaxx BL Conversion
Hyper-7 Truggy
E-Slayer
09.21.2008, 08:34 PM
I did the opposite with my revo, and turned it into a slayer. The arms, driveshafts, pushrods, and toelinks are different. The tranny is also different, and you will need a small pinion to get the right gearing with revo size tires. I am sure that you could get 60+ for the used parts on ebay. It would be a 2.5 revo length after you finished, and would need a second steering servo, or maybe a high torque servo...
phatmonk
RC carbon junkie
phatmonk's Avatar
09.24.2008, 06:26 PM
I put the Tekno swaybars and converted the hubs to 17mm to use 1/8 buggy tires I am using a badlands tires as Linkpimp did.I love my E-Slayer.Just keep trying.
bruce750i
bruce750i's Avatar
09.24.2008, 06:56 PM
I feel that way sometimes when my slayer is upside down 400 feet across the parking lot. Or when I ease it into a turn, and still see the two inside tires go in the air.
blueb8llz
09.24.2008, 09:57 PM
what kinda springs did you try. i suggest some stiiffer springs. whats the stock wt oil? i suggest putting in 10-15 wt heavier than stock.
