Hello, everyone! I'm new in the neighborhood. I've got a Duratrax Evader ST EP and my current project is a Traxxas E-Maxx (see my avatar).
I'm not currently brushless, but I've been reading the forums with great interest. I have to admit, though, that I still wrestle with the cost factor...and that's just thinking about it casually! :eek:
So I have to ask [puts Nomex undies on] -- what is so bad about the Novak brushless systems? How does the new HV-MAXX stack up compared to setups like the Warrior 9918 and a Feigao 9L?
I have a 7xl and a 9918 and there is no comparison (18 cells) I got it here, and it cost the same or a little less than the HV-maxx. Not to mention the spectacular customer service. A guy at my local track had the HV set up and it seemed like a lot of money for what it did. But I am also comparing it to what I have. He drove my truck and couldnt belive the power it had. Also I belive you are more limited on how many batt. you can run. I think you can only run 14 cells with the HV, and 16 with a 9l. One thing I do like is the heat sinks that come with the HV. I purchased some for my 7xl for about $3 online. I would recomend rc-monster.com over the HV-maxx setup by far.
I should have a heatsink/motor clamp available soon. It is currently under development and should be available anytime. This will work with any Feigao/Hacker size 540 can motor ("s", "L", or "XL"). I hope to have these available in a week or so. These will function as a heatsink, but will also have a clamping action to hold the pressed endbells together. This should make the Feigao type motor a much more attractive purchase, as you will not have the threat of a popped can. It will be a two piece design and the price should be in the $20-$30 range.
I will be mounting a fan on top of the heatsinks and the 9918 soon. But will have to check out the one from Mike also. Dont forget to answer HV-MAXX question.
Ryan, are you running 48 pitch pinions/spur? If so, how do the teeth hold up? I considered moving to 48 pitch gears, but I was told they just wouldn't hold up in the E-Maxx.
Ryan runs a big motor, which makes the pinion/spur LOOK small. The Novak systems are pretty decent. They are more powerful than stock and get a better runtime with near zero maintenance. The systems most on these forums runs are a little more extreme in the power department (well, Ryan's is a LOT more extreme in the power department). The Novak systems are pretty good, and smooth, but in terms of pure power, most of the setups here will easily outperform the Novak.
Thanks. Let me know when you are ready. You can also e-mail me direct if you have any unanswered questions. Glad you are enjoying the forum and website, too!
I did alot of researsh before I purchased my BL system. RC-monster.com got me hooked. I started out with replaceing the motor and controlor. Now the only thing left stock is the servo and the radio.
LOL! I will keep that in mind! I think it will probably be a while before I can make the jump to brushless, though, simply due to the economics of that upgrade...not to mention the really stern looks I'll get from my wife when she sees the bills! :eek:
Originally posted by Megazone23 LOL! I will keep that in mind! I think it will probably be a while before I can make the jump to brushless, though, simply due to the economics of that upgrade...not to mention the really stern looks I'll get from my wife when she sees the bills! :eek:
