Need help/advice on my setup
pumpkinfish
Need help/advice on my setup - 10.21.2008, 10:53 AM
Need some help/advice guys. This weekend while racing, I had a problem hitting the 15min mark for our A-main. I made it to 14 min and the LVC stopped me. I am wondering if I should go to a 4s 6000 mAh pack, buy a more efficient motor or some other variable I didn’t consider.
At the 14 min mark my pack had used 4508 mAh (confirmed this on recharge). I had zero warm up laps and plugged in the car at 30 seconds to start. I drove as smooth as possible and tried to avoid excess movements and speed where necessary. By my calculations, I would have needed 5152 mAh to run 16 minutes (would like a little extra comfort plus a warm up lap) + extra to not run the pack down completely. I am concerned the weight of a 4s 6000 mAh pack would be too much.
I just bought a new MBX6 for next summer so I know I will have some weight savings. Until that arrives and is built/shaken down, I am currently using my Kyosho mp777 WC.
Specs as it was raced:
Kyosho mp777 WC
Castle Mamba Max with lowest motor timing, no drag brakes
Neu 1512/2D/F
Neu 30C 5000mAh 4S1P pack
46t Kyosho Plastic Spur
car was geared to top out at 40.6mph with the 12T (quals) and 37.2mph with the 11T (main)
I was having such a good race too. I got tangled up early, worked my back up to 5th but ran out of juice. I need to finish these races and represent the flashlights better
