SC8 Conversion Thread
marzac2
marzac2's Avatar
SC8 Conversion Thread - 11.06.2008, 08:56 PM
Well I thought I'd start a thread for SC8 conversions.
Mine is underway and should be completed in a week.
Take a look at the pictures and you can see all I have done is remove the engine and electronics.
Also if you look at the last picture, you can see that I installed window screen with a hot glue gun from the inside of the body to give a more scale appearance.
Losi 8 Buggy + Truggy & Associated SC8
Tekno RC Conversion Kits on all
MMM, MGM, Xcelorin ESC's
Tekno Neu "square can" brushless motors
Polyquest - Neu - Flight Power LiPo's
skellyo
skellyo's Avatar
11.06.2008, 09:02 PM
Wow, these are getting to be popular conversions this week. This is the third one I've seen that's being converted...aside from the POS conversion SC8 on eBay.
hootie7159
"1.21 GIGAWATTS!!!"
hootie7159's Avatar
11.06.2008, 09:05 PM
window screens!!!...great idea...i'm gonna do the same thing to mine 2morrow once it gets here!!!...
Losi SCTE
MMP/1410 3800kv
2s 65C 5600mah proteks
Dx3s
marzac2
marzac2's Avatar
11.06.2008, 10:20 PM
Thanks.
I've been doing it to my Losi 8B/T bodies for about a year now with great results. Just cut out the screen about 1/2" over the actual window size. Position the screen inside the body, and start applying the glue to the top of the window, let it dry a bit. And holding the screen tightly from the bottom, apply glue there to make sure your screen doesn't come out saggy. After which, you can finish applying glue to the rest of the windows perimeter.
Good luck!
11.06.2008, 11:12 PM
How much was it for the SC8 kit?
skellyo
skellyo's Avatar
11.06.2008, 11:18 PM
They only come as a RTR and most sites have them at about $650 right now.
11.06.2008, 11:19 PM
lucias
lucias's Avatar
11.10.2008, 07:39 PM
What are the main difference between an sc8 and rc8t?
rchippie
rchippie's Avatar
11.10.2008, 07:47 PM
Sc8 has buggy arms versus truggy arms .
REAL MEN RUN BRUSHLESS
marzac2
marzac2's Avatar
11.12.2008, 02:18 AM
Heres an update.
The pictures are below for your drooling pleasure!!
It is a prototype in testing. Chassis is new, along with other standard Tekno parts, including the clutch, make this conversion super scale. I can creep around on the ground with a small blip of the throttle at 1 mph if I want. Rolling around on and off throttle on pavement or blacktop produces the most amazing tire squelching. The sounds are soooo realistic and cool!! And just seeing one of these bad boys coming to a screeching/screaming stop at full brakes (mechanical), will make just about anybody want one.
Let me know what you think or if you have any questions.
jnev
jnev's Avatar
11.12.2008, 02:25 AM
Damn, that looks great! Is that the new Tekno Neu motor with the built in mounting holes?
lucias
lucias's Avatar
11.12.2008, 02:36 AM
Is it a noticeable difference in run time when you use mechanical brakes?
marzac2
marzac2's Avatar
11.12.2008, 03:22 AM
Yaa. It is the 3D - 1360kv. Gives the cleanest install and lowest CG by a small amount.
Not really. Most of the real benefits are noticed right away and mostly they are performance related. Ability to coast through the air off jumps with ease. Slow rolling corners with confidence in the consistency of the "roll". And also the ability to adjust brake bias. The ability to have the rear end of the car brake before the front makes for consistent handling through corners and tighter turns.
I think the temps are noticeably lower though... so extra run time might also be noticed, though I haven't tested for it.
Thanks for the comments.
lucias
lucias's Avatar
11.12.2008, 10:23 AM
Looks awesome can't wait to see a video of it running... This truck is on my I need list not my I want list... LOL
11.12.2008, 10:33 AM
