i beat u
tyrewq
i beat u - 11.26.2005, 10:25 PM
my bl emaxx with 20cells and 4 AA receiver batts only weigh 10 lbs. how much did i beat u by? :)
squeeforever
squeeforever's Avatar
11.26.2005, 10:35 PM
i dunno but my brushless maxx on 12 cells weighed only 8 lbs.
Basketti
11.26.2005, 10:44 PM
my soon to be bl emaxx is weighing 12lbs with 14cells thats including wheels and tires, is yours including wheels and tires?
tyrewq
11.26.2005, 10:59 PM
ya, everything, maybe both you guys got too many alu parts
squeeforever
11.27.2005, 12:52 AM
8 lbs is light for a max.
Basketti
11.27.2005, 12:57 AM
Yeah my maxx is all aluminum except for the chassis and chassis braces lol. My aluminum chassis is coming in the mail.
JOHNNYMAXXIMA
RC-Monster Dual Brushless!
JOHNNYMAXXIMA's Avatar
11.27.2005, 06:19 AM
Dang squee, how did you get that so light?
nbcaznmaster
RC-Monster Cult Member
nbcaznmaster's Avatar
11.27.2005, 09:28 AM
wow...my e-revo with CARDBOARD ON IT! weights 9.5 lbs! how do u guys do it?!?!?!
We are all talking about FULL trucks. With batts, tires, bodies, EVERYTHIGN. Cuz i find ur weights to be hard to believe.
~~~~~~~~RC Garage~~~~~~~~
LSP-R - Picco .26
Nitro Revo - .18tm
coolhandcountry
coolhandcountry's Avatar
11.27.2005, 09:45 AM
the lightest i have heard of it mikes. He has a 7.5 lb maxx rtr. I have mine at 8.5 and 9lbs. It will be okay though. Just need bigger motor to carry it. :D
Peace!
Country
Help support the
Rc-Monster
Buy here
nbcaznmaster
11.27.2005, 10:38 AM
how do u guys do it?!?!? even a revo isnt that light.
LSP-R - Picco .26
Nitro Revo - .18tm
need weight
tyrewq
need weight - 11.27.2005, 12:16 PM
welp, after bragging about it's lightness i just got punished today. i was on my first drive with the a new aluminum spur and the 20 cells. for a short time i was in heaven. it was pullling mini wheelies at not even a half throttle and was so responsive, i was amazed. and then after 10 seconds, "whirr, whirr , whirr". it just whirrs and won't move. i found out that the center transmission got a broken spur connection to the shaft. the small pin that holds the shaft to the spur twisted the spur!
i'm looking at ebay right now for a hardened steel center transmission. if anyone know where i could buy these unbreakable ones, please tell me! thanks
I WANT THAT WHOLE CENTER SECTION BULLETPROOF!!
coolhandcountry
11.27.2005, 12:40 PM
I am not sure what pin you talking about. If you run the light weight gears they will not hold to bl. I run the stock gears in the tranny for the strength. just need the metal idlers. I you talking about the roll pin in the input shaft it has happened before.
Peace!
Country
Help support the
Rc-Monster
Buy here
ttrmike
got truck
ttrmike's Avatar
11.27.2005, 12:41 PM
I have a whole Sportwerks center diff assembly with a harded steel spur.
tyrewq
11.27.2005, 12:45 PM
are you selling it?
can you show a picture of it? and can you count the number of spur teeth, thanks
tyrewq
11.27.2005, 01:29 PM
ok, i'm cool now, i dremeled a couple of jagged edges on the aluminum spur and replaced the worn out pin with sowing pins, and geared down the pinion from 22 to 20 teeth. it should hold until i get a real bulletproof system.
